Author Topic: R32 Query  (Read 2448 times)
Offline Martz
R32 Query
« on: 15 May 2007, 13:30 »
Hi
Hope someone can answer this. Are there any reported problems relating to the accerlator. The car idles low and then shoots off at a higher RPM.
Is this a fault that anyone is aware of?
Regards
Martyn
Offline Creepy Coupe
Re: R32 Query
« Reply #1 on: 15 May 2007, 13:44 »
Hi
Regards
Martyn
Not sure what you mean by shoots off at higher rpm, mine idles around 650-700 rpm and is very has very quick throttle response on light throttle.mine is also a manual if that helps.
Offline Martz
Re: R32 Query
« Reply #2 on: 15 May 2007, 13:48 »
The vehicle in question is auto. It can be described as when you push the throttle down there is a slight delay. It jumps from say 3k to 7k instantly?????
Re: R32 Query
« Reply #3 on: 15 May 2007, 13:52 »
Oh no nothing like that sorry, sounds like a visit to the dealers needed.
Offline Rhyso
Re: R32 Query
« Reply #4 on: 15 May 2007, 14:38 »
clutch slip? :undecided:
could be a software issue  :undecided:  have you got access to VAG COM to scan for faults?
Offline ressla
Re: R32 Query
« Reply #5 on: 16 May 2007, 00:28 »
hi, im not exactly sure what u mean. in my manual when driving normally at say 3000, then once i release the accelerator to change gear, it suddenly shoots up to 6000 or so.
