Author Topic: What is it?  (Read 3268 times)
Offline Ant
What is it?
« on: 07 February 2004, 23:26 »
While going through various problems on the car today I noticed a broken wire, but can not identify the component.
There is a smallish cylindar to the right and lower of the drivers side headlight which has two wires (both yellow I think) what is this/what does it do>
Offline Dizzie
  • Make friends with your fast
Re:What is it?
« Reply #1 on: 08 February 2004, 00:26 »
I think it's the coil for the heated screen, but I'm probably wrong.
turbo
Re:What is it?
« Reply #2 on: 08 February 2004, 01:38 »
my guess that this is the outside temp sender for the mfa.....
Offline wolfman
Re:What is it?
« Reply #3 on: 25 February 2004, 13:31 »
If yours is a late model sounds like the control for the dim-dip system. I think this was added about 1990 because of European legislation. When you put your side lights on this automatically turns on your dip beam as well but with less power i.e., it appears dimmed. Effectively makes the sidelights look brighter. There should be a slight delay before the dip beam kicks in.    :)
Veedubgt18v
Re:What is it?
« Reply #4 on: 25 February 2004, 18:34 »
wolfman sounds about right! the outside air temp for the mfa is on the passenger side way down in the bottom of the wing. i cant think why the heated screen would be wired into the headlites  ???
Veedubgt18v
Re:What is it?
« Reply #5 on: 25 February 2004, 18:35 »
but we love ya anyway diz!  :-*
Offline Gambit
Re:What is it?
« Reply #6 on: 26 February 2004, 12:44 »
it might also be for the electric headlamp levellers which UK cars didnt get but the wiring is their for
Blue MK2
Re:What is it?
« Reply #7 on: 26 February 2004, 12:57 »
are you on about that 3 pin connector for the leccy headlamps?
Offline mysticman aka polypathetic
Re:What is it?
« Reply #8 on: 26 February 2004, 13:24 »
at a guess i would say it was a heat sink to stop the headlights from overheating or a capacitor this would be the case if the car has high power headlights
Offline Gambit
Re:What is it?
« Reply #9 on: 26 February 2004, 14:36 »
high power headlamps are certainly not a feature of std mk2 golfs!
