Author Topic: Power assited steering  (Read 1551 times)
Offline Ant
« on: 07 February 2004, 22:34 »
Ok finally managed to get to track down my PAS leak, it's coming from the boot on the passenger side of the bellows.
How easy is this to replace (and what needs to be replaced) it's a home do-able 2 spanner job or should I stick it into my local expert?
How much would this cost?
89 G reg 16v Gti
« Last Edit: 07 February 2004, 22:37 by DakoYam »
Blue MK2
Re:Power assited steering
« Reply #1 on: 07 February 2004, 23:29 »
do you mean the pipe?
i have a small leak at the pipe from the power steering bottle. :(
golfvr6
« Reply #2 on: 08 February 2004, 18:00 »
could be a seal gone in the rack.
Offline mk1
« Reply #3 on: 08 February 2004, 20:28 »
Agree with '6, your problem is more than the boot. The rack is leaking internaly filling the boot with pas fluid and leaking out. Replacement rack required ::).
Steve.
Offline Ant
« Reply #4 on: 13 February 2004, 06:28 »
Ok, so if a seal is gone in the rack is this replace able? amd if so is this a job I can do myself or is it complex?
