Author Topic: Second opinion Or Advice urgent  (Read 1038 times)
Offline pricey
« on: 13 May 2007, 17:24 »
Ok where do i start since owning my mk2 great car but nothing but water problems.
Ok to start with its had a new thermerstat.
now since yesterday the car was blowing cold in from heater thought nothing of it then started to play with a wrx and as soon as i put my foot down in third gear the oil temp went right up and so did the temp gauge, i pulled over and water was pouring out of expansion bottle.
About an 5 hours later topped up water still cold air out of heaters but engine temp and oil temp fine did not rev it over 2k.
Also checked that there is no oil in water and vice versa.
So the help i need after doing a search on here.
Do i change water pump,
Do the bypass thing to heater matrix
Buy a new bottle cap
Or is there something else wrong
cheers in advance
« Last Edit: 14 May 2007, 19:56 by pricey »
Offline Mart8V
  • I really should know better by now.....
Re: Second opinion Or Advice
« Reply #1 on: 13 May 2007, 18:25 »
Sounds as though your "new" thermostat may be duff, or you have a nice big air lock somewhere in the system.....  Try those before you launch into more expensive repairs.
Offline pricey
« Reply #2 on: 13 May 2007, 20:11 »
It would be nice if its a big air lock.
need it to be right as i off to mod nationals in a couple of weeks.
Offline Simon8v91
« Reply #3 on: 14 May 2007, 11:26 »
Check water pump drive belt tension and condition  :smiley:
Cant think of anything else not already mentioned.
Offline pricey
« Reply #4 on: 14 May 2007, 16:29 »
Took the pipe off expansion bottle good flow so looks like its not water pump.
Just run the car till temp hot just topped up and will try it later :smiley:
Offline pricey
Re: Second opinion Or Advice urgent
« Reply #5 on: 14 May 2007, 19:57 »
bleed system fine had lovely hot air untill i got stuck in traffic then heater went cold ans stayed there
Offline Gambit
« Reply #6 on: 14 May 2007, 20:01 »
if it aint overheating/boiling over anymore etc, then cut the bypass valves out of it..
Offline pricey
« Reply #7 on: 14 May 2007, 20:08 »
Just checked no signs of boiling over so will b&q it tomorrow for some 22 mm copper pipe  :smiley:
And hopefully that will work
