Author Topic: Heater Control Lights  (Read 3602 times)
Offline jezza16v
Re: Heater Control Lights
« Reply #10 on: 16 May 2007, 17:50 »
My heater controls aren't very readable at night, though there is a light on... is that normal?
They dim along with the clock dimmer wheel, you sure they're not turned down very low?
Can you get a bulb that size lower than 1.2 watts?       :undecided:
Offline bored_Welsh_lad
« Reply #11 on: 17 May 2007, 07:34 »
the bulb i got was low lol very low!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Overseer
« Reply #12 on: 17 May 2007, 14:12 »
so if this is a wrong bulb thing.. whats the right one?
btw if i remember right.. i took mine apart to look for the bulb. drove to halfords with the dash apart.. and fixed it back together outside in 2 mins (hence upside down light pipe bit)...  mines lighter around the central knob as i think its not spreading to the sides doh!
Offline garfayliu
« Reply #13 on: 17 May 2007, 14:24 »
sounds like the light guide isn't aligned properly, thats the transparent piece of plastic that looks like a spider. basically it works a little like a fibre optic and directs the light from the bulb to each of the heater dials and panel.
mine looks like this, some parts are brighter than other, but in real life it's all illuminated, if you have aircon, theres a blanking plate behind the 'air conditioning' part on the panel which can be removed so that the words illuminated aswell.
Offline Overseer
« Reply #14 on: 17 May 2007, 14:57 »
hence the following lol..
mines hard to read too.. but i think i put a bit for one of the light pipes back in upside down?
« Reply #15 on: 17 May 2007, 15:15 »
gary what bulbs did you use? or did you use leds?? i have been looking for the correct resistor/led pairing for these for a while see
Bumper Vents :D
Offline garfayliu
« Reply #16 on: 17 May 2007, 17:54 »
they can also crack/snap if so then they won't transmit as much light through.
