Author Topic: MK3 Service Display reset tool  (Read 1922 times)
Offline eightyeightmph
« on: 12 May 2007, 16:33 »
Does anyone have one they would lend me, or know where to get one cheapish?!
The IN02 'error' displays on the LCD on start up, have just had a 20,000 mile service but was at my local garage which isn't part of VAG so they couldn't reset it.
Anyone help out over here?!
2016 GOLF GTD
Offline boneybradley
  • Back in a Mk3...
Re: MK3 Service Display reset tool
« Reply #1 on: 12 May 2007, 18:20 »
try this link or look at the top of the mk3 section!!!!!
http://www.golfgtiforum.co.uk/index.php?topic=8052.0
Offline golfdubcrazy
« Reply #2 on: 12 May 2007, 21:29 »
as far a i rember all you have to do is press the millege reset button and hold it for 5 - 10 secs then turn the igntion on while still holding the button hold it until you see " --- " and your done
Offline jezza16v
« Reply #3 on: 13 May 2007, 15:41 »
I used the info in above the link to clear 'IN 02' this morning, it worked fine. You need to use the mileage reset buttons and the clock minute adjustment buttons. Just follow the link......  :smiley:
« Reply #4 on: 14 May 2007, 08:36 »
Cheers for that!
2016 GOLF GTD
Offline frog
« Reply #5 on: 14 May 2007, 11:00 »
Carried this out on mine following the guide at the top of the MK3 section. Worked fine no problems
Offline monkeyalan
« Reply #6 on: 14 May 2007, 12:04 »
you should have gone to VW and let em charge you £50  :laugh:
