Author Topic: where is the fog light switch?  (Read 2300 times)
Offline Ciaran
« on: 07 February 2004, 12:54 »
on my 1991 16v 3dr just out of interest! ???
Offline modulater
Re:where is the fog light switch?
« Reply #1 on: 07 February 2004, 15:34 »
Its located in the switches to the left of the instrument cluster.
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 07 February 2004, 15:35 »
shouldn't it be on the steering column being a 90 spec an' all?
Offline chevychase
« Reply #3 on: 07 February 2004, 15:35 »
its the same switch as the back 1. first click the front fogs come on and the second click the back come on
Offline modulater
« Reply #4 on: 07 February 2004, 15:42 »
your getting confused dizzy, thats the hazard light switch.
Offline Dizzie
« Reply #5 on: 07 February 2004, 19:12 »
I dunno what the f**k I was thinking there then. I've sure I read it as hazard switch.
What's that mum? Yeah I'll take my pills in a minute ;)
Offline Ciaran
« Reply #6 on: 08 February 2004, 02:16 »
doesn't work tried it on one click and 2 but it still did not work! why?
Offline Ant
« Reply #7 on: 08 February 2004, 10:05 »
For me it was cause the bulb had gone, only one side has a bulb unless you wire across to the other cluster, can't remember which side is fog.
Other than that check the power to the switch does it illuminate, does the little orange bit at the bottom light (note that this won't light if the bulbs blown but the switch will still illuminate) if you work out it's your switch I think I've got a spare, I'll check later.
Offline Ciaran
« Reply #8 on: 08 February 2004, 14:14 »
well the light on the switch does not work but the rear fog does must be a bulb like u say!
