Author Topic: will a 16v downpipe fit  (Read 666 times)
Offline richard s
« on: 09 May 2007, 21:18 »
i could do with changing my downpipe and i would like to fit a 16v downpipe i as i have a 2 box stainless system that is too loud
so is the 16v downpipe similiar in diameter to the 8v one fitted at moment
also what problems am i likely to have fitting a new downpipe
car is a 1990 8v gti cheers
Offline j_s
Re: will a 16v downpipe fit
« Reply #1 on: 10 May 2007, 15:08 »
16v downpipe diameter is larger than the 8v so you would need an adapter sleeve made up for downpipe to front section, not sure about manifolds though.
James
« Reply #2 on: 10 May 2007, 15:12 »
manifolds are totally different engine side, but a 16v downpipe will plug into an 8v manifold & vice versa.  Other issue is the 16v system is a larger bore as J_S said.  The 16v system is 2.25" & the 1.8 8v systems are 2", if you can get an adaptor made up or use a 16v system then you can fit a 16v downpipe to your 8v :)
Offline richard s
« Reply #3 on: 11 May 2007, 21:30 »
cheers guys i will see what size my downpipe to front section clamp is and take it from there
