Author Topic: 16v  (Read 1555 times)
Offline ecomoto
16v
« on: 08 May 2007, 21:26 »
Hi everyone iv recently took possesion of a 96 16v gti,just had 17 rs4 reps fitted and hav suspension and filter on way,before this i had owned mk1 gti,mk2 lotus cortina,306gti6 ad=nd most recent fiat coupe 20vt.Anyway i wanted to know which you think is the chaepest way to 200bhp+ as miss performance of fiat,dont wana change the car,so is it to tune 16v engine(headwork etc) vr6 transplant +mods or turbo the 16v motor.i await your kind advice.thanks
Offline Len
Re: 16v
« Reply #1 on: 09 May 2007, 09:34 »
You can get approx 175bhp with filter/zorst/chip/remap.
Thats the same as a standard VR6. Or 180bhp for a Seat 1.8t (VW is 150bhp)
So an engine swap wont get you more than a 16v with first stage work.
And you will need to do more work to get 200bhp.
So the easy route will then be cams and headwork on the 16v.
www.sas.org.uk
www.the-ace.org.uk
Offline ecomoto
Re: 16v
« Reply #2 on: 09 May 2007, 19:01 »
cheers len,do you have an idea what cost i would be looking at for said items and cam headwork? cheers
Offline Len
Re: 16v
« Reply #3 on: 10 May 2007, 08:56 »
Well a K&N is about £80
A good exhaust say £300
A chip/remap at somewhere like Stealth or AMD is around £300
Cam and headwork - I think you can get a Stage 3 head with cams for around £400 but not sure on that.
Someone else I'm sure will correct me!
www.sas.org.uk
www.the-ace.org.uk
Offline ecomoto
Re: 16v
« Reply #4 on: 14 May 2007, 21:12 »
soz for the late reply thanks for that info,the car has done 166k with full fsh,would you advise to tune engine with this mileage.ta
Offline bored_Welsh_lad
Re: 16v
« Reply #5 on: 15 May 2007, 08:17 »
Just a thought but the coupe has brembos as standard doesnt it??? id say that will be your best bet in upgrading on the golf. See whether your budget permits a bigger set of calipers as my mates coupe stops on a 20pence piece
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Len
Re: 16v
« Reply #6 on: 15 May 2007, 09:21 »
Normally no.
If I was doing it I would get a spare engine and strip it completely. Do all the headwork, check all the bearings and rings etc.
I mean you can do the K&N and exhaust anyway then fit the reworked engine then get remapped chip.
www.sas.org.uk
www.the-ace.org.uk
Offline ecomoto
Re: 16v
« Reply #7 on: 16 May 2007, 22:02 »
yeah coupe had brembos as standard but they wasnt anything special to be honest! once i have more power i would upgrade the braking.cheers. yeah maybe il sitick with external tuning untill i decide to get vr6 or 1.8tmk4.cheers len
