Author Topic: Noob Needs Help... GT TDi 130  (Read 6351 times)
Offline stu1210
« on: 08 May 2007, 11:33 »
Hi People...
last week i got myself a Golf GT TDi after much hunting...
I have a few questions...
Firstly... i have a balnk display panel under the warnings display.. The part that is meant to show the Trip mileage, Fuel Consumption, Temp etc... I have the Toggles on the wiper stalk but can't get the display working... It lights up red when lights are on so there is power to the unit...
Also i have no audio warning that my lights are on when i open the car door.
And my interior light on the bottom of the Driver door isn't working... (this could be a bulb though as i haven't checked yet)
Could all of the above be related?.. If they can be fixed easily can someone tell me how!?...
Thanks in advance
Stu
Offline Maka
Re: Noob Needs Help... GT TDi 130
« Reply #1 on: 08 May 2007, 17:57 »
Could be some sort of fuse mate,
what colour, age, mileage etc mate?
They are nice cars, but do have little faults that shouldn't cost too much to fix...
Offline teash
« Reply #2 on: 08 May 2007, 19:03 »
what colour
you mean it might have somert to do with the cars colour,  :grin: :grin: :grin: :grin:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #3 on: 08 May 2007, 19:24 »
There is no audiable warning if you leave the lights on is there?? unless i am immune to mine :laugh: :laugh:
If the door light is not a bulb and you have a silver car it is probably the door switch, if you have a black one then............ only joking, it will still be the dor switch :grin: :grin: :grin:
Offline Rhyso
« Reply #4 on: 08 May 2007, 20:39 »
does your remote locking still work and also the interior coutersy light?
if not then its def a fuse otherwise as Gaz has said its mostly the door switch
Offline stu1210
« Reply #5 on: 09 May 2007, 09:14 »
Sorry..
Colour is Tornado Red.. on an 02 plate...
1 owner from New, FVWSH, 83k...
I have no interior courtesy light either... i'm guessing the door module is at fault.. The car locks fine and the windows/mirrors work great... and i checked the bulb yesterday and i have no power going to the light unit...
Any idea's on my half display?.. Is taking the cluster our fairly easy!?..
Offline GarryR
« Reply #6 on: 09 May 2007, 09:49 »
I've got an audible alarm in mine when i leave the lights on and open the door. :huh:
GT TDI 130, OZ Aristo wheels (Genuine R32's), Eibach springs lowered 40mm, angel eyes and HID Conversion
Offline Ridg
  • TDI - Soot Happens!
« Reply #7 on: 09 May 2007, 11:41 »
the light should come one when you unlock the car on the key fob, so i'm guessing that as you've got no light its going to be the fuse like Maka said.
Offline Rhyso
« Reply #8 on: 09 May 2007, 11:46 »
does the light come on if you switch it on manually?  if it does then its your door lock.  if not then its a fuse.
the door lock etc is located behind the panel.  behind that is a metal panel.  have a look at this friend for an idea how to remove it
http://forums.vwvortex.com/zerothread?id=1015107
and how to repair it (should it need it)
http://forums.vwvortex.com/zerothread?id=1542461
Offline stu1210
« Reply #9 on: 09 May 2007, 16:54 »
yes mate.. it definately must be the door lock module...
the courtesy light works fine for all the other doors... only the drivers that is playing up!...
I'll investigate tonight!.. Is the Speedo cluster easy to remove or is it a major job!?...
