Author Topic: Electric windows - Help!!!  (Read 951 times)
Offline trojandub
« on: 07 May 2007, 10:28 »
I have just bought a mk3 golf gti and also have a problem with the electric windows, which i understand is common on golfs! I have tested and there is power going to the switch connector and i have also changed the switch itself. Does this mean that it is the motor that is knackered (when the switch is pressed there is no click or noise) or is there an easier solution. Hope somebody can help Thanks
Offline adyh
Re: Electric windows - Help!!!
« Reply #1 on: 07 May 2007, 16:27 »
Check the wires in the rubber boot that connects the wires to the main body . You might have a split , shorted cable .
