Author Topic: i need educating  (Read 3816 times)
Offline jk
i need educating
« on: 06 February 2004, 13:49 »
what purpose does the forge dv 007 do, where can i get one and how much are they.
i know its stupid but i'm new to this stuff.
2000 gti turbo, oettinger rear spoiler,rs4's, k&n
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:i need educating
« Reply #1 on: 07 February 2004, 01:37 »
Forge DV 007 is a dump valve (hence the DV)
It acts as a more efficient replacement for the standard wastegate system (which vents excess boost pressure during throttle lift off).
Basically, when you lift off the throttle on a turbo charged car (to change gear for example) you need to vent the pressure side of the system to allow the turbo to be able to spool up again when you get back on the power.
If your engine is running more boost than standard the wastegate system will not be capable of venting all the excess pressure, so the turbo will be battling to spool up against the back pressure retained within the system, and you'll have Turbo lag (as well as a prematurely knackered turbo).
Cost? from ?100 I guess, not running one, so I can't say, I'm sure one of the petrol boys will chip in with the cost.
The greatest leveller of them all - the Carousel
Offline jv
  • Administrator
Re:i need educating
« Reply #2 on: 07 February 2004, 01:43 »
blimey all those big correctly spelt words at this time of night!
mr jk, you need to go here:
http://www.forgemotorsport.co.uk/products.asp?cat=TUNDV&catalog=TUNDV
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline S11EPS
Re:i need educating
« Reply #3 on: 07 February 2004, 01:45 »
I took me a long time to type that correctly!
After a lot of 'friday night abuse'!
Offline topher
  • Administrator
  • fully functioning
Re:i need educating
« Reply #4 on: 07 February 2004, 01:48 »
about to pay ?90 inc VAT with free fitting, thanks to vince at stealth  ;D
Offline Starry
  • http://planetweed.co.uk
Re:i need educating
« Reply #5 on: 07 February 2004, 08:01 »
i run a revo'd turbo and i use a baily dv 30 very good indeed ?99 and it takes 15 mins to fit. but 007 is just as good.just make sure what ever one you buy it a reciurcalating(sos about spelling) one as then you dont get the boy racer ppssssst every time you change gear.
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
Offline snowball
Re:i need educating
« Reply #6 on: 07 February 2004, 10:01 »
i got one of em but i aint got a clue how much it cost jbs did everything under the bonnet ! but makes a nice noise when i change gear  ;D
2000 vw golf cab S3 engine , revo'd , s3 clocks , 18" rims, LSD, sps3 controller , nos ,RR sheet coming soon.
www.jbsautodesigns.co.uk
Offline jk
Re:i need educating
« Reply #7 on: 08 February 2004, 11:31 »
cheers for the help lads, is there much point in me getting one as i havent done anything to the engine apart from an induction kit.  by the way running an 1.8t 150brake.
Offline S11EPS
Re:i need educating
« Reply #8 on: 08 February 2004, 14:29 »
Get an anti lag system instead!
Offline gazzagtiT
  • Houston, we hav a pic here!!
Re:i need educating
« Reply #9 on: 08 February 2004, 14:37 »
Ah, intresting, how does an anti-lag system work then! apart from prevents turbo lag!! ;)
Its all better now very shiny, but now the windows have gone again! and shocks are squeaking like mice!!aarrgghhh
