Author Topic: Indicator flashing too fast?  (Read 3870 times)
Offline mk2mark
« on: 06 May 2007, 16:38 »
Have a problem with my indicators, when I indicate right it flashes faster as if one of the bulbs was gone - but neither are :shocked: What's the craic? Electronics aren't my forte...
Offline rowlers
  • I'm back - MK7 GTI
Re: Indicator flashing too fast?
« Reply #1 on: 06 May 2007, 18:34 »
take the relay out see if it is damp - I had some strange indicator goings on when I had a leak over my fusebox!
I blew it out with an DRY air line and that cured it!
Offline Adam_C
  • Mk4 Golf R32
« Reply #2 on: 06 May 2007, 18:53 »
check the earthing for the rear lights there might be a loose connection or something. thats what happened to mine.
Offline jenson
« Reply #3 on: 06 May 2007, 18:54 »
Could be the flasher unit itself?
Offline mk2mark
« Reply #4 on: 14 May 2007, 09:41 »
Ok guys, I'm pretty sure it's not the relay, how would I check the grounds on the rear lights if they're all working? Would the flasher unit not be working for the right hand side only??
Offline JMallows
« Reply #5 on: 14 May 2007, 14:30 »
You say neither bulb was gone... did you check the third bulb?
A clever person solves a problem. A wise person avoids it.
Offline mk2mark
« Reply #6 on: 15 May 2007, 21:38 »
Yeah I couldn't find it! There's only 2 unless I'm seriously mistaken, which would be severely embarrassing :laugh:
Offline takethefifth
« Reply #7 on: 15 May 2007, 21:55 »
Front, back and side unless you have a blanking plate in place of the side one.  :smiley:
Offline Mr Blue
« Reply #8 on: 16 May 2007, 09:01 »
Does it flash faster when you press the brake pedal?
Ive got this in the mk3. Cant understand it
Offline JMallows
« Reply #9 on: 16 May 2007, 13:02 »
Yeah, the third bulb is on the wing. Unless its missing... then it would flash faster too!
Blue, sounds like a bad earth in the boot, all the rear lights share the same earth at the back, could be worth a look?
