Author Topic: Temp sensor  (Read 812 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Temp sensor
« on: 06 May 2007, 12:21 »
Is it possible to pull off a plug to make the Temp warning light come on/flash
It usually comes on then goes off with ignition but it only does it every other time.  i wanted to make it come on and see if its in the wiring or something else
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
