Author Topic: Option codes on the Mk4  (Read 4328 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« on: 04 May 2007, 07:46 »
I went to check out my future purchase and got the following from entering the option codes into this website http://igorweb.org/equidec/Default.aspx
1J1 = sound deadening package
X1D = national sales program Sweden
B0N = component parts set, complying with vehicle type for Great Britain, various parts
C3K = cast alloy wheels 6 1/2J x 16 "BBS", one-piece, offset 42 (1J0 601 025 R, TIREX 6)"
G0K = 6-speed manual transmission
H6U = tires 205/55 R 16 91W
J0R = battery 380 A (80 Ah)
D3A = 4-cylinder turbo diesel engine 1.9 L/110 kW TDI with pump-jet injection system, EU 3, base engine is T20
Q4P = sports front seats
1AT = electronic stabilization program (ESP)
1G2 = steel spare wheel with original equipment tires
2PX = leather trimmed sports steering wheel
1NL = covers for alloy wheels
5RV = outer right rear view mirror: non-spherical
5SJ = outer left rear view mirror: convex
T20 = components for, base engine, unit 038.R
0BB = rear stabilizer
3S0 = without roof rails/roof load rack
3U1 = foldable trunk cover
QG1 = service interval prolongation
0G4 = cable gearshift
8GL = alternator 120A
8L3 = roof antenna
1H0 = without proportioning valve
1KS = disc brakes, rear (Geomet D)
1ZE = disc brakes, front (Geomet D)
3YR = door pockets with insert mats
G86 = front sports shock absorption
0GE = emissions concept EU 3
4UE = airbag for driver and front seat passenger
4X1 = side airbag front
4R4 = power windows with comfort operation and circuit breaker
4K3 = radio remote controlled central locking operated from inside and safe securing
N4M = partially leather seat covering
5MD = decorative aluminum inserts
8RM = eight loudspeakers (passive)
2JC = comfort bumpers
E0A = no special edition
0AE = front stabilizer
1JC = rear shock absorption for sports design
L08 = suspension range 08
0YZ = without determination of weight category for rear axle
Just wondered if anyone knew more about the highlighted options.
X1D = national sales program Sweden - I know it came into the country via somewhere in the EU, must have been sweden then.
N4M = partially leather seat covering - It's got cream leather, so does that mean it's leatherette and not leather?
L08 = suspension range 08 - What does this mean?
Also there does not seem to be a code for the winter pack, xenons, cruise etc that are fitted.  And there is no code for a stereo so can only assume one was not fitted.
Cheers for your help.
Offline Ridg
  • TDI - Soot Happens!
Re: Option codes on the Mk4
« Reply #1 on: 04 May 2007, 09:49 »
not sure about the highlighted ones.
Regarding the xenon's and winter pack, i'll check my book and see if those are listed on mine.
Offline Ridg
« Reply #2 on: 06 May 2007, 11:15 »
this is what i get
Quote
X2B = national sales program Great Britain
J0L = battery 340 A (70 Ah)
1AJ = anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
8AD = radio "gamma"
8L3 = roof antenna
3FE = electric slide/tilt sunroof with sun screen/sunblind
4R4 = power windows with comfort operation andcircuit breaker
5MW = decorative inserts, dark myrtle wood
2J2 = impact bar in doors (US version)
0YZ = without determination of weight categoryfor rear axle
Mine neither shows the winter pack or xenons, so someone has either gone to a lot of trouble to fit the winter pack and xenons or they aren't shown in the list.
regarding the part leather, mines full black leather so that description is messed up, not sure on the suspension, might just be the code to say its the same as the 1.8T
