Author Topic: Reverse Lights  (Read 1825 times)
Offline dub_Driver
Reverse Lights
« on: 03 May 2007, 09:56 »
 Anyone had a problem, mine have decided to just randomly stop working for some reason??
 Its no the bulbs or fuse, so im lost??
 JJ  :cry: :laugh:
Offline BobbyT
Re: Reverse Lights
« Reply #1 on: 03 May 2007, 10:08 »
mini havent worked for two years, i had a look but couldnt find where the switch is on the gear box!  :undecided:
Re: Reverse Lights
« Reply #2 on: 03 May 2007, 10:15 »
jump the 2 wires to the switch together on the gearbox, if they come on its the switch, if they dont its the wiring or fuse.
The later switch is a 2 pin jobber and is screwed into the top of the box, if its an early one you might find its part of a MPG/shiftlight switch which is screwed into the side of the shifter hump.
Dinky
Re: Reverse Lights
« Reply #3 on: 03 May 2007, 19:47 »
Mine hasn worked since ive had it :laugh:
its not an mot failure anyhoo..unless thats changed as well?! :undecided:
Dinx :kiss:
Offline BobbyT
Re: Reverse Lights
« Reply #4 on: 03 May 2007, 20:25 »
it get annoying when you have to pull out and you know other people wont know! but hey!  :rolleyes:  :wink:
Offline [han]
  • Graphic Designer for Haribo
Re: Reverse Lights
« Reply #5 on: 04 May 2007, 09:30 »
mine don't work either, altho im sure they did,
if its not an mot fail, then im ok! :)
Offline KittyMk1
  • ~ VolksGirls.co.uk ~
Re: Reverse Lights
« Reply #6 on: 04 May 2007, 09:38 »
my reverse lights on my cabriolet dont work, so i changed the switch and they still didnt work, then when i went to work one day someone told me the reverse lights were on when i was driving forward. must be wiring somewhere.
Offline LITTLEGADGI
Re: Reverse Lights
« Reply #7 on: 06 May 2007, 18:02 »
 :angry:MINE STILL DO NOT WORK EVEN AFTER A £20 NEW PART FROM GSF, WORK MANUALY FINE  BUT NOT IN SITUE WOTS GOING ON :cry:
