Author Topic: Would these ARB's fit my car?  (Read 1902 times)
Offline haf1zur
« on: 03 May 2007, 08:39 »
Offline Len
Re: Would these ARB's fit my car?
« Reply #1 on: 03 May 2007, 09:22 »
Bit steep!
I have seen that Wietec do a front only for £120.
Dunno if changing the back will help much.
www.sas.org.uk
www.the-ace.org.uk
« Reply #2 on: 03 May 2007, 10:06 »
if your car has 5 stud wheels then it will fit, otherwise no it wont :)
Offline haf1zur
« Reply #3 on: 03 May 2007, 16:43 »
thanks, what would improve handling most, these arbs or coilovers?
hafizur
Offline Len
« Reply #4 on: 03 May 2007, 16:48 »
Well now you're asking!
Coilovers will lower your car and therefore have stiffer damping/springing.
This combined with the lower centre of gravity of the car will improve handling.
Just the stiffer anti-roll bars will improve handling.
Which is better I cant tell you!
www.sas.org.uk
www.the-ace.org.uk
Offline 2.0gti!
« Reply #5 on: 05 May 2007, 17:07 »
if you want to be really serious about it then id say coilovers , anti roll bars , full poly bushes , and strut braces are the only answer all of that combined will make your car handle incredible.
i should know thats wot im running on my car!
 :cool:
Offline Len
« Reply #6 on: 06 May 2007, 12:51 »
^^^ But then you end up with a harsh bone shattering ride!
If you want some comfort then just do the ARB's.
If you want the best handling possible then do all he said above!
www.sas.org.uk
www.the-ace.org.uk
Offline pw motorsport
« Reply #7 on: 07 May 2007, 10:30 »
As suggested above to anti-roll bars like there name suggest will control the body roll, will little or no loss in ride quallity.
Quality coilovers will lower, firmer and control the damping better.
Springs alone can be used to control body roll, this is not ideal. You will need much harder springs leading to poor ride quality. Harder springs will also case the standard dampers work too hard. As they are unable to control the deflection of the stronger springs.
Anti-roll bars front and rear work very well. The rear makes a huge difference.
Offline haf1zur
« Reply #8 on: 08 May 2007, 14:52 »
i think i will go with arbs then strut braces and finally coil overs
would it make it feel like the R32? or better?
though it might be a dumb question as the R32 is 4x4
hafizur
Offline Len
« Reply #9 on: 08 May 2007, 14:57 »
Ummmm no comparison to an r32!
www.sas.org.uk
www.the-ace.org.uk
