Author Topic: ABS Light  (Read 2050 times)
Offline Mboy
ABS Light
« on: 01 May 2007, 12:16 »
Hi my ABS light has stopped coming on on my 98 MK3 GTI, is there an easy way to check to see if its the bulb that has blown ?
Offline Len
Re: ABS Light
« Reply #1 on: 01 May 2007, 12:41 »
Drive fast and slam on yer brakes! Soon see if your abs is working! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Mboy
Re: ABS Light
« Reply #2 on: 01 May 2007, 13:13 »
my brakes seem fine ,so just wondering if blub has blown, how do i get to it !??
Offline garfayliu
Re: ABS Light
« Reply #3 on: 01 May 2007, 13:43 »
take out that bit of trim, a small philips screw driver or even finger nails on the side edge nearest the window and it'll just pop off. bulbs available from dealer for a quid or two.
Offline Len
Re: ABS Light
« Reply #4 on: 01 May 2007, 13:46 »
Yes but have you made the ABS work?
Do it! You dont have to be driving that fast, say 30mph on a very quiet road, something like a Trading Estate one evening, just hit the brakes really really hard.
If it is only the bulb there must be a way of getting to it. But do the test first! :wink:
But be warmed it can be fun and become addictive! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Mboy
Re: ABS Light
« Reply #5 on: 02 May 2007, 17:08 »
checked car and bulb has blown, where do i get a new one from ?
Offline cs98sss4
Re: ABS Light
« Reply #6 on: 02 May 2007, 21:32 »
I thought the unit was complete and couldn't change the bulb.
Golf MK3 16V ABF "Anniversary"
Offline Mboy
Re: ABS Light
« Reply #7 on: 02 May 2007, 22:08 »
pulled unit out and the bulb is just soldered on, will a normal bulb do or does it have to be from vw ?
Offline Bazzer
Re: ABS Light
« Reply #8 on: 03 May 2007, 07:19 »
well if you've got one there to compare it to, anything with the same voltage and wattage will be fine - it should be stamped on the glass somewhere....
Bazzer
Offline garfayliu
Re: ABS Light
« Reply #9 on: 03 May 2007, 08:15 »
a bulb from an xmas tree would work, but the proper bulb from vw is £2, soldering is only 2 pins, easy if you have a soldering iron and a desoldering sucker thing. replace it for a led and resister.
