Author Topic: Amp power cable  (Read 4010 times)
Offline kieran
Amp power cable
« on: 04 March 2003, 13:25 »
Somebody help me before I resort to drilling holes in my car!!
I've got an 8v GTi and I need to find a way of getting an amp power cable from the battery through the bulkhead and into the car so I can run it to the boot.
I had a quick look this morning before work and for the life of me couldn't see anywhere for it to go.
Any suggestions????
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline stoat
Re: Amp power cable
« Reply #1 on: 04 March 2003, 16:43 »
There are loads of places what you need to do is have a look behind you engine and you will see loads of rubber gromits by you passenger side into you car.  Some may have cables already going through them.  Make a SMALL hole through one of these ones with out any other cables, then slide the cable through it the hole will stretch giving you a water tightish hole.  In side you car you will need to remove the shelf below your glove box and pull the carpet away.  With the gromit removed you should be able to see daylight if not try another one until you have success.  But dont drill any holes there is no need to.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
MK3 GTI 8V
Offline stoat
Re: Amp power cable
« Reply #2 on: 04 March 2003, 16:45 »
ps you must put a gromit in the hole with the wire going through it, this will stop the wire from getting cut by metal in your body work
MK3 GTI 8V
