Author Topic: lights on single headllight grill  (Read 932 times)
Offline gti south
« on: 30 April 2007, 20:24 »
where would i be able to get headlights that have full beam as well. for converting the headlights to just two not four lights. many thanks
Gti 8v not bad for a first car
Offline Organisys
  • Old and Slow...
Re: lights on single headllight grill
« Reply #1 on: 30 April 2007, 21:11 »
There is good news my friend. The main beam is built into the outer lamps. The smaller inner lamps are just spot lights only and come on as well as main beam.
 :smiley:
Offline gti south
« Reply #2 on: 30 April 2007, 21:39 »
mmm okies so if im having better bulbs as well it wouldent matter then. whats the point o0f the middle lights? style?
Offline Teletom
« Reply #3 on: 30 April 2007, 21:58 »
The inner spots provide extra illumination - I've had 2 and 4 light grilles and the difference is noticeable, it's not just a styling thing
When the great scorer comes to write against your name, he marks not that you won or lost, but how you played the game - HST
Offline gti south
« Reply #4 on: 30 April 2007, 22:09 »
mmm ok il see but if im using stronger light bulbs it should be the same
Offline vw-bob
« Reply #5 on: 30 April 2007, 23:05 »
ive noticed on my quad lamp that the centre lights only come one when i have full beam on. yet the switch on the dash that does the rear high intensity has 2 settings. pushing half way does nothing, but pushing it fully in turns the rear lights on. a friend of mine has a mk1 and he can turn the inner lights on his golf independently (hope i spelt that right). has mine been re-wired? or is this just a different set-up on the light switching?
Offline Mart8V
  • I really should know better by now.....
« Reply #6 on: 30 April 2007, 23:11 »
Different set up.  The first stage on the fogs switch is for the fronts, if fitted (eg big bumper).
Offline Organisys
  • Old and Slow...
« Reply #7 on: 01 May 2007, 12:36 »
It will help. Some of the Phillips or even halfors uprated bulbs are good. Also you can fit an uprated headlamp loom which I noticed helps quite a bit as well.
Have a look for the looms on ebay or PM 'Dizzie' on here.
