This weekend i am fitting new rear brake's (mainly due to a knackered wheel bearing and worn disc's).. I have bought the disc's and i am wondering about the abs ring's..
1. Are these fitted to my car on the rear's??
2. if so should i replace them???
3. is there any advice/tip's that could make the job a bit easier??
I have bought new rear disc's,full bearing kit's for both side's,pad's and pad fitting/anti squeele kit..
and it's a 1995 8v with 280mm front brake's (I am sure they changed the abs system for the 288mm set up???)....
Thanks in advance
