Author Topic: Fuel pump  (Read 2645 times)
Offline Golfgal
Fuel pump
« on: 05 February 2004, 14:58 »
my mk1 gti makes a god damn awful noise - same as mk2 wen fuel pump went. If I replcae this I'm hoping it will b quiet.
Anyone done this b4 and do u reckon I cud do it? I have a haynes manual and a whole set of tools but not a lot of knowledge he he. :)
V5 Beetle owner. I'm just here for the misfire threads....
Offline MK4_20VT
Re:Fuel pump
« Reply #1 on: 05 February 2004, 15:13 »
I don't think the Mk1 has a pump in the tank, which causes the Mk2's main pump to buzzzz when it's on it's way out (that happend to me)
P.S how is the 90 psec trim comming along of da guy?  ;D
« Last Edit: 05 February 2004, 15:14 by 84_MK2_Black »
Offline Golfgal
Re:Fuel pump
« Reply #2 on: 05 February 2004, 15:37 »
oh yeah I'll email him now. Actually u can do it Peter.Munns@avon-rubber.com
so wat is buzzing from rear then - it sounds the same
Offline AdamB
  • The Perfect Storm
Re:Fuel pump
« Reply #3 on: 05 February 2004, 17:23 »
Had the fuel pump off, on my cab, should be the same as yours,it  wasn't too hard a job, but you really need to get it up on a ramp, as its not in the easiset place when its sat on the deck
« Last Edit: 05 February 2004, 17:57 by AdamB »
I don't own this anymore - I just can't be arsed to change the picture
Offline Golfgal
Re:Fuel pump
« Reply #4 on: 05 February 2004, 17:37 »
kewl
 might just get someone to do it for me
Offline moonsta
Re:Fuel pump
« Reply #5 on: 06 February 2004, 00:47 »
 :) if you don't get it sorted before bring it with you when you come to get the clocks and we'll sort it out........... :D
Drives '96 Polo 6N and '85 Mk Golf Gti...
Offline Golfgal
Re:Fuel pump
« Reply #6 on: 06 February 2004, 12:13 »
Awwww that would be the best!! Thanx poppet :d where will I get a fuel pump from then?
Offline hairyarse
Re:Fuel pump
« Reply #7 on: 19 February 2004, 10:59 »
Just seen your post on the noisy fuel pump.
Mine buzzes constantly!! (Which a mate told me not to worry about until the buzzing stops!!  ;D)
Anyway, I hear too it can be a common problem and had heard of someone have this problem on their MK1 for over 4 years!
I will probably replace the pump at some point as the noise can be a little irritating but other than that I don't think it is a huge problem whilst it is still pumping the juice around!
Offline Golfgal
Re:Fuel pump
« Reply #8 on: 19 February 2004, 14:16 »
Its a major problem for me - I have no ice in my car and need asprin everytime i've driven it he he!!
Thanx for the tip though  :)
Offline MK1_BOY
  • Low Low bored out MK1 Golf GTI Campaign.
Re:Fuel pump
« Reply #9 on: 23 February 2004, 17:59 »
I changed my pump over with a new one from GSF, its is easy really, just need to remember to clamp the fuel pipes going into it otherwise you tank will drain...  Even when I changed pumps  the noise didnt disappear so shouldnt worry about t little noise, might want to check you have the rubber sound proofing around it as this does stop allot of the noise...  Hope this helps  ;D
Race ya...
