Author Topic: Mk2 lowering...help required please.  (Read 665 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 28 April 2007, 17:47 »
Got my springs ready to lower my mk2. exactly what do i need in order of spanners to lower the car f+r? i know i need spring compressors, jack etc, just not too sure on the spannerage. any help appreciated.
Offline Mew
Re: Mk2 lowering...help required please.
« Reply #1 on: 28 April 2007, 18:10 »
You are going to need a swan neck ring spanner (22mm i think) or a suitably bodged socket for the fronts! As well as an allen key to stop the shock spinning whilst undoing the top nut.
^That is the most awkward bit of the job if things don't want to come undone!
Then i think it is a 19mm for the bolts that hold the shock body to the hubs. Possibly a 17mm for the rear top mounts.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 28 April 2007, 19:30 »
spark plug socket, with spanner that fits, and allen key, I found this the best solution for getting the fronts out.
Also you'll need the strut nut tool, otherwise its a ballache to get the nut off! I get a complete VAG set of ebay for about a tenner.
19mm and 17mm spanners sockets mole grips to stop the rear struts turning.
I think thats about it! :wink:
Offline dan7
« Reply #3 on: 29 April 2007, 10:59 »
Thanks guys. mucho appreciated! Will let you know how i get on....
Offline Mart8V
  • I really should know better by now.....
« Reply #4 on: 29 April 2007, 12:40 »
You can also use a vortex socket for the fronts- makes life much easier.  Make sure that you leave a block under the rear discs when you have the wheels off-  don't want to dent them like a mate of mine did when they crashed down!
