Golf mk3
hardmonkeys
Mk3 - 2 quick questions before i buy it!
Topic: Mk3 - 2 quick questions before i buy it! (Read 1250 times)
Giorgio
Just got here
27 April 2007, 16:46 »
I have looked at a few mk3 golf tdi's and have found what seems to be a good one. 2 questions...
The drivers window does not work - when i press the button there is a quiet click from inside the door, but the window doesnt move. Is this likely to be an easy fix from a scrapyard?
Also - when driving over 50, the steering wheel vibrates indicating balancing/tracking...but on a receipt from last year the mechanic had noted that the power steering pump (i think it was pump) was loose because the holes were worn. Could this be the cause of the vibrations and hence be expensive to fix?
gtitdi
Here all the time
Re: Mk3 - 2 quick questions before i buy it!
28 April 2007, 08:30 »
hi
my mk3 had the same window problem in the back - it just clicked. it turned out to be the earth going to the motor throught the door hinge (inside the rubber boot) that had snapped - this seems to be a common problem.
not sure about the pas pump but i wouldnt have thought a loose one would cause vibrations - more likely to be wheel balancing (about £5 a wheel).
hope that helps!
irmscher
Mobile Engine Tuning www.premiertuning.com
29 April 2007, 19:17 »
Quote from: stehornsey on 28 April 2007, 08:30
Or possibly a steering rack??
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com
or
Facebook
Len
10k hero
30 April 2007, 09:23 »
Vibrations throught the steering wheel are things like, wheel balance, bent wheel, warped disc,track rod end worn.
www.sas.org.uk
www.the-ace.org.uk
KittyMk1
GTI forum regular
~ VolksGirls.co.uk ~
30 April 2007, 09:32 »
i'd try the tracking first then check to see if the discs are warped. my mates mk3 gti got through loads of discs, mind u he was on the brakes all the time the idiot.
Last Edit: 30 April 2007, 09:34 by GirlieMk1
bored_Welsh_lad
30 April 2007, 12:03 »
tracking is if a car pulls in a direction...
balancing will more likely resolve vibration as the wheels arent true which is why weights are added
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come
Bumper Vents
Golf mk3
hardmonkeys
