Author Topic: Sticky Throttle  (Read 1072 times)
Offline tallpaulr
Sticky Throttle
« on: 27 April 2007, 12:26 »
It's a problem I've had since getting my 16v, if I gradually nail the throttle there's no problem, but if I plant it every now and again the throttle sticks open and takes forever to loose the revs. As you can appreciate it's not a good thing when your car won't do as it's told!!!
Any idea's?
Offline Len
Re: Sticky Throttle
« Reply #1 on: 27 April 2007, 12:34 »
Some WD40 around the throttle linkage?
www.sas.org.uk
www.the-ace.org.uk
Offline tallpaulr
Re: Sticky Throttle
« Reply #2 on: 28 April 2007, 12:41 »
I tried that and disconnected tthe throttle cable and drowned it in WD as well to see if it was catching in there but it didn't make any difference.
Offline bored_Welsh_lad
Re: Sticky Throttle
« Reply #3 on: 30 April 2007, 12:10 »
might be freyed cabling within the throttle cable.. or that the cable needs greasing?
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline tallpaulr
Re: Sticky Throttle
« Reply #4 on: 30 April 2007, 17:51 »
When you pull on the cable when it was disconnected it felt free enough so i don't think it was that
