Author Topic: mk3 2l 16v lumpy tick over  (Read 1867 times)
Offline the gimp
« on: 25 April 2007, 18:45 »
All the fault codes have been cleared although the knock sensor 2 fault ocationaly reoccurs.
I've replaced the plugs dizzy cap and rotor arm and it runs smooth through the rest of the rev range.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: mk3 2l 16v lumpy tick over
« Reply #1 on: 26 April 2007, 10:46 »
A Blocked injector mabey?  Try a shot of redex, sometimes helps.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Len
« Reply #2 on: 26 April 2007, 10:53 »
Mine is lumpy too. But its putting out loads of power so not gonna worry about it!  :smug::grin:
www.sas.org.uk
www.the-ace.org.uk
Offline the gimp
« Reply #3 on: 27 April 2007, 18:45 »
have aplied redex to a full tank will let you all know
Offline cs98sss4
« Reply #4 on: 27 April 2007, 19:21 »
could it be the ISV blocked up with crud?
Golf MK3 16V ABF "Anniversary"
Offline the gimp
« Reply #5 on: 27 April 2007, 21:56 »
isv is that the tubular device on the top of the front of the engine underneath the inlet manifold with the sliding part in it ?
Offline cs98sss4
« Reply #6 on: 28 April 2007, 00:23 »
I think so it has a plastic pipe from the airbox leading into it on one side. It should be under the plastic cover.
Offline the gimp
« Reply #7 on: 28 April 2007, 23:05 »
I cleaned that out and tested it and it apears ok, the redex apears to be starting to work, the tickover is getting less lumpy
Offline Overseer
« Reply #8 on: 30 April 2007, 18:11 »
how about turning the air-con off? often that smoothes mine out a treat..
