Author Topic: Odd noises  (Read 2008 times)
Offline Onge
Odd noises
« on: 04 February 2004, 23:10 »
Hi all,
Can you assist?
Someone at work owns a MK4 golf 1.6 SE (new ish )
They are hearing clunging noises when they change gear, and a creaking noise from the rear of the car when they drive over uneven roads.
Any ideas what the noises can be?
Cheers :)
kniterider
Re:Odd noises
« Reply #1 on: 05 February 2004, 12:57 »
noises!!!! hhhmmmmm, the rear end could be the bearings/bushes in the rear beam, or spring or damper, cant really narrow it down, take a can of wd40 and spray areas mentioned (dont get any on brakes) then see if noise disappears!, clunking noises when changing gear, are they pressin clutch pedal??, sound stupid i know but some peeps get lazy and dont fully depress the clutch then wonder why they have difficulty changing gear, if not that then a clutch/gearbox prob???or broken engine mount causing engine to rick when changing gear??
Offline Onge
Re:Odd noises
« Reply #2 on: 05 February 2004, 13:54 »
Cheers,
I'll pass on the info
