Author Topic: Radio not turning off  (Read 1608 times)
Offline takethefifth
Re: Radio not turning off
« Reply #10 on: 25 April 2007, 00:47 »
Definately sounds like the remote wire isn't correct. I seem to remember the remote wire (auto aerial) is blue or yellow out of the back of the headunit? Check them all with a multimeter to find the one that powers up to 12v when the headunit comes on. Once you have the right one on the amp you shouldn't have a problem, headunit off and the amp goes off.
Wiring into a ignition switched live from the head unit results in you having to reset your clock and radio stations everytime you turn the ignition off/on. You could do it with the amp but may blow fuses due to the load. As a rule i always connect my amp direct to the battery with an inline fuse.  :smiley:
« Reply #11 on: 25 April 2007, 11:54 »
the pre-90 MK2s have a group of ign live spades on the rear of the fusebox, simply run a wire from this to the ign live feed to the head unit.  If you take it out you'll probably find it has the live & ign live feeds jumped together to the live feed which is why it doesn't switch off :)
Offline Wrighty_1988
« Reply #12 on: 25 April 2007, 17:09 »
Ive got it done  :grin: Ive wired it up to my electric antenna wire comming out the back. Works great, thanks to everyone for help :)
