Author Topic: hose sizes  (Read 993 times)
Offline rowlers
  • I'm back - MK7 GTI
hose sizes
« on: 24 April 2007, 17:42 »
anyone know what size the breather inlet is on the side of the airbox (that the crank case breather connects to) of the KR?
Just trying to sort out the lengths of hose I need to plumb my catch tank in.
The catch tank has 8mm inlets, so need to reduce/increase from these to the right size of the breather pipes.
Would go outside and measure, but 1 its p|ssing down and 2 can't leave my 21mth old daughter in house on her own while I go out!!!
cheers :wink:
Offline monzablue16v
Re: hose sizes
« Reply #1 on: 24 April 2007, 18:35 »
19mm I think mate and 31mm onto the block that's ID and I'm not 100% on that :) go measure it lol
Offline rowlers
Re: hose sizes
« Reply #2 on: 24 April 2007, 19:22 »
19mm sounds good to me!!
19mm to 3/8 - could be intesting!
Re: hose sizes
« Reply #3 on: 24 April 2007, 19:26 »
Thats the problem I had dude let me know how you get on take pics and do a how to :)
Offline rowlers
Re: hose sizes
« Reply #4 on: 24 April 2007, 19:33 »
you're right!
19mm or 3/4''!
Whos got a little bit then? :wink:
Offline rowlers
Re: hose sizes
« Reply #5 on: 24 April 2007, 20:16 »
my theory is to heat a bit of 9mm id hose up (hair dryer etc...) and slide this over the 3/8'' in/outlets of the tank this will increase the OD of the in/outlets to closer to the 19mm of the breather pipe.
Also I have no idea where or how I am going to mount it?!?
I tell you what though I aint blowing half as much smoke when larging it with the oil breather plugged into my temp lucozade bottle "catch tank" instead of the airbox!!!
Offline rowlers
Re: hose sizes update....
« Reply #6 on: 28 April 2007, 13:17 »
Just getting the plumbing sorted for my catch tank here it is so far:
Just need another reducer made up:
than I'm good to plumb in!
Anyone know how/where to mount the tank at???
« Last Edit: 30 April 2007, 17:29 by rowlers »
Offline rowlers
Re: hose sizes
« Reply #7 on: 30 April 2007, 17:29 »
do you think it will work???
Re: hose sizes
« Reply #8 on: 30 April 2007, 19:12 »
Looks alright that matey bit more swish than a lucozade bottle :laugh: I'd get some jubilee clips on there though to stop it peeing all over the engine bay if it pops off. I'd mount it up on the front panel next to the radiator just try not to block the airflow too much :)
and I'd have inlet at the bottom outlet at the top :)
« Last Edit: 30 April 2007, 19:15 by monzablue16v »
Offline rowlers
Re: hose sizes
« Reply #9 on: 30 April 2007, 19:18 »
it will be in by the weekend so I'll get some pics up!
