Author Topic: BBS RM  (Read 818 times)
Offline RJT
BBS RM
« on: 24 April 2007, 13:16 »
Can some body post some pics on how to successfully seal these f***ing wheels.
thanks in advance.
Offline Gambit
Re: BBS RM
« Reply #1 on: 24 April 2007, 18:17 »
1. go to B&Q, buy some "High Modulus" bathroom sealent - bout a £5 a tube - it  must be high modulus so as to allow the seal to flex without breaking.
2. put a thin film between the mating faces, then bolt together, do not over tighten the bolts
3. then run the sealent around the channel on the back of the rim between the outer rim & inner rim, and force down into the join.
you can do step 3 alone if you just want to reseal them without having them apart
also, check the valve seating, put some sealent round back of it also as it leaks sometimes
Offline vaughn
  • now team wagon, and team grumpy trainee
Re: BBS RM
« Reply #2 on: 24 April 2007, 18:18 »
there you go :smiley:
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
