Author Topic: 1.6 ABU engine  (Read 1964 times)
Offline theviper
1.6 ABU engine
« on: 23 April 2007, 22:29 »
how can i tell if the head gasket has gone without taking it apart ????
a friend says i can have the car for £50 but he thinks the head gasket has gone will be seeing the car tomorrow
Thank's Pete
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: 1.6 ABU engine
« Reply #1 on: 23 April 2007, 22:40 »
White gunge on the oil cap
Crap in the coolant
oil/water leaking out the head gasket
heavy miss fire
burning oil
Best thing is to get a compression tester in there and see.
Im sure i have missed a few common symptoms there, some one else will fill them  in i'm sure   :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline theviper
Re: 1.6 ABU engine
« Reply #2 on: 23 April 2007, 22:44 »
would the car still start up then ???
« Last Edit: 23 April 2007, 22:59 by theviper »
Offline DogDay
Re: 1.6 ABU engine
« Reply #3 on: 23 April 2007, 23:12 »
quite possibly yes... the amount of frothing dogs I see at the auctions suggests that most blown head gaskets will run after a fashion...
DD :cool:
Bow Chikka Wow Wow
Offline Rmachines
Re: 1.6 ABU engine
« Reply #4 on: 23 April 2007, 23:52 »
Some will run fine, others will run rough, allot wont start at all.
Offline DogDay
Re: 1.6 ABU engine
« Reply #5 on: 24 April 2007, 01:14 »
what car is it? if it's half decent & has an MoT - if you don't want it i might :grin:
DD :cool:
Bow Chikka Wow Wow
