Author Topic: tappets  (Read 1548 times)
Offline richard s
tappets
« on: 22 April 2007, 21:57 »
other than the dealer part are gsf & euro car parts tappets any good
only reason i ask is my 1990 8v gti 2.0 bottom end doesnt seem to tap on tick over but when i drive between cars etc i can hear what i think is a tappety noise but i can not identify it because my exhaust is to bloody loud does any one get this tapping noise when driving all help opinions & ideas as to what else this noise could be are greatly recieved thanks
Offline GTI-BOY
  • It's a love / hate relationship
Re: tappets
« Reply #1 on: 22 April 2007, 22:05 »
I can recommend the hydraulic lifters from GSF cos I got them about 2 years ago and they quietened the engine down a lot! Is your oil pump ok though?
Blown Gearbox :(   Now replaced :)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: tappets
« Reply #2 on: 22 April 2007, 22:44 »
Hydraulic lifters do get tired and can become noisy, although not excesively unless the spring inside, (which you cant get at) is broken up. The said spring is the component that gets tired and/or the ball seat in the tappet is no longer perfect.
You may of course have a performance cam and quick bleed down tappets which are noisy by design anyway.
Offline rowlers
  • I'm back - MK7 GTI
Re: tappets
« Reply #3 on: 23 April 2007, 18:04 »
have a loo on the "other" forum, there is a lifter refurb guide, they do come apart!!!
Alternatively £30 quid for a set of 8 on ebay! I have them in my valver, and they are sweet!
Offline dabill
Re: tappets
« Reply #4 on: 23 April 2007, 18:41 »
hiy,
i get a tapping in all gears between the 1,500 to 2,000 revs. it sounds like only one tappet is out of time tbh, but i've been told it wont make any difference to my engine and not to worry about it immedietly, is it worth getting it changed? and is that whats happening with the main thread?
rob
noble tuned - and still not fast enough!
Offline monzablue16v
Re: tappets
« Reply #5 on: 23 April 2007, 19:00 »
You sure it's your tappets and not the engine pinking? both sound pretty similar and when I got mine tuned up my noisy tappets magically dissapeared. :)
Offline richard s
Re: tappets
« Reply #6 on: 23 April 2007, 19:37 »
it has been tuned but i did not give the guy rubjonnys set up guide so i dont know if it was set up as it should be. would it make any difference if blue temp sender was not unplugged or timing not set at 2500 rpm also as for tapping or pinking i think i will have to get someone to drive the car past me so i can hear it better
Offline cняis
Re: tappets
« Reply #7 on: 23 April 2007, 20:16 »
pinking almost sounds like metal cracking when you put the engine under load (i.e. 5th gear, 2k revs and full throttle) and is a bit erratic. noisey tappets make more of a regular slapping noise, often worse when the engine is cold.
slapping noises when the engine is hot could indicate "piston slap", but would be heard coming through the block and not the head. i havent heard of a mk2 with piston slap though.
my 8v digi was set up last week using rubjonny's guide but still pinks as the head needs a de-coke, and is therefore suffering from hot-spots (i.e. fuel is igniting before its meant to)  :cry:
Offline richard s
Re: tappets
« Reply #8 on: 24 April 2007, 21:46 »
I CANT DECIDE WHAT IT IS BECAUSE OF THE EXHAUST (2 BOX STAINLESS SYSTEM VERY LOUD) I HAVE BEEN TOLD IT IS LOUDER THAN ONE OF THE LADS AT WORKS OLD CARS THAT ONLY HAD A BACKBOX
Offline xxdansigxx
Re: tappets
« Reply #9 on: 30 April 2007, 09:01 »
i know what u mean m8t my car is the same sounds like a race track round mine when im revving it lol that what the neighbours say anyway ;) lol
