Author Topic: Attaching amp board, Have a Look!  (Read 1246 times)
Offline Paulo_Gti
« on: 21 April 2007, 13:15 »
Im in the process of organising my boot space and phase 1 is putting my two amps somewhere... ive made a sidewall out of wood and its cut to fit but i need to secure it somehow...?
Any ideas, i would have just self tapped it to the inner arch but the fuel tank is around that area!
Just to let you know i will be covering it with carpet!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Attaching amp board, Have a Look!
« Reply #1 on: 21 April 2007, 13:35 »
I have this problem.  I thought of either making "L" flanges and gluing/screwing to the floor and top where possible but its still only theory at the moment, i havn't looked to see exactly where it could go
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Paulo_Gti
« Reply #2 on: 21 April 2007, 13:39 »
probably if i was more gifted with my tools i would have made it fit upto the back seat and screwed a bracket onto there but it kinda defeats the object of putting the seats down if needed! :sad:
giffy1988
« Reply #3 on: 23 April 2007, 17:48 »
this is what i did with my boot, its all 100% remoovable via clips (for the wires) and room for all the tools and bits n bobs underneath fink it looks good 2  :grin: :rolleyes:
Offline -scott-
« Reply #4 on: 23 April 2007, 17:52 »
You shoudl try to do this guys if you have the time.Its easily removable if ur wanting it in and out.Yeh its been made for a sub but if you were to modify the front of it slightly when building it then it could do exactly what you want.
Im planning on doing it when i have the time.Bought the fibre glass and resin and everything at the weekend for it.
Here you go,its worth a look.
http://www.talkaudio.co.uk/vbb/showthread.php?t=76606
Scott.
Mrk 3 Golf VR6 Colour Concept
Offline Paulo_Gti
« Reply #5 on: 24 April 2007, 19:38 »
Cheers guys, had a word with len and my amps are fitted and securley too. Looks the nuts!
once my fiberglass shell has set il get some carpet on the sub inclosure and amp board. :wink:
Offline Len
« Reply #6 on: 24 April 2007, 20:26 »
Glad to be of assistance!
Keep us posted on the sub build mate.
www.sas.org.uk
www.the-ace.org.uk
Offline Rmachines
« Reply #7 on: 25 April 2007, 08:23 »
How did you attach it in the end?  did you make an FG enclosure for it?   After seeing that post about it i really want to make one  :smiley:
Offline Len
« Reply #8 on: 25 April 2007, 08:59 »
The GF stuff is going in the other side for his sub box!
Didnt exactly tell us how he fixed it!
I only told hime where he could fix it to!
www.sas.org.uk
www.the-ace.org.uk
