Author Topic: Im worried. My wheels dont look right  (Read 1433 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 21 April 2007, 00:19 »
I have noticed something.
My driver side wheel sticks out further than the passenger side.  It is a good 6mm past the wheel arch, where as the other is dead level.  its as if it has a spacer fitted but it hasn't.  Why is this?? i hope it doesn't fall off.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline cняis
Re: Im worried. My wheels dont look right
« Reply #1 on: 21 April 2007, 00:20 »
check your wheel nuts!!
if its not that then u need to be looking at wishbones/front subframe etc...
sharpie
« Reply #2 on: 21 April 2007, 01:12 »
car had any history of accidents?
as said in the post above, could be bent  :undecided:
Offline Rmachines
« Reply #3 on: 21 April 2007, 01:47 »
it has defiantly taken a shunt to the back, the rear panel where the GOLF Badge is, doesn't line up with the boot or tail lights.
As long as nothings going to come off and kill me i'm not to worried if its generally a bit out of shape.  I'm going to have it up and wheels off to change the suspension springs soon so i will have a good look then.
Offline DogDay
« Reply #4 on: 22 April 2007, 07:21 »
got the same on mine - top of the driverside front wheel sticks out further - I only noticed it after I put new shocks on - I just figured the camber was well out - not got it sorted yet as i am swapping the springs soon...
DD :cool:
Bow Chikka Wow Wow
Offline Rmachines
« Reply #5 on: 22 April 2007, 12:02 »
ahh rite well my new shocks and springs are going on this week so i will have all the geometry set up when thats done and see how it looks then.  :smiley:
Offline Gambit
« Reply #6 on: 23 April 2007, 21:05 »
get a proper 4 wheel alignemt, they be able to tell you if the car is bent simply by measuring the thrust angle of the car
Offline Rmachines
« Reply #7 on: 23 April 2007, 22:43 »
cheers i will do that when my suspension is fitted.  :wink:
Offline clipperjay
« Reply #8 on: 24 April 2007, 17:06 »
Some factory shells came out like that. One side sits more about 10mm sometimes and is only apprent when you put bigger alloys on as the arches show up the differences in the ET.
It's something to do wioth the shell not sitting flush on the chasis at the factory quiet common.
There is someone who machines spacers to level them off CNC machined. More common on the MKII I'm asuming yours is a MKIII?
It's nothing to worry about if chamber and tracking have been set to compensate for any deviations, asthetically it will eat you up when your mates think you have an alloy bigger than the other. It shouldn't be more than 10mm if it is get it checked if your history is incomplete.
Jay
Offline Rmachines
« Reply #9 on: 24 April 2007, 17:31 »
Hi. thanks for that info its really helpful! Yea it is a MKIII and Its deffo no more than 10mm.  a few people have said how nice and wide the wheels are, so i'm not complaining.  its fine until i turn the car around and it looks normal  :grin:
