Author Topic: Pinking problem causing high oil temp? - RESULT!!  (Read 2299 times)
Offline cняis
Re: Pinking problem causing high oil temp? - RESULT!!
« Reply #10 on: 21 April 2007, 12:43 »
sweet. timing set at 2k ish is correct.
try shell or BP 89/99 RON petrol and she will fly.
i think you mean "98/99"  :wink:
Offline Organisys
  • Old and Slow...
« Reply #11 on: 10 May 2007, 12:09 »
 :rolleyes:
Offline rowlers
  • I'm back - MK7 GTI
« Reply #12 on: 10 May 2007, 20:33 »
try an ATF flush to decoke your engine, 1/2 a liter of auto transmission fluid in your oil, run for a week or 200 miles ish, but don't rev the nuts of it!
drain an fill with synta!
worked on my valver, oil temps av dropped by about 4degrees!
Offline cняis
« Reply #13 on: 10 May 2007, 21:50 »
i will give that a go, cheers :)
due for an oil change in about 3 or 4k miles
Offline jammac
« Reply #14 on: 11 May 2007, 10:53 »
what price did you pay for all that?
ITS A TRAP!
Offline ...joe
« Reply #15 on: 11 May 2007, 15:30 »
fully synthetic doesn't work too well with older engines you want semi in there. stick with VW synta silver and you can't go too far wrong.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
