Golf mk3
hardmonkeys
ABS relay/fuse
Topic: ABS relay/fuse (Read 2311 times)
DazVR6
mk3 VR6...FEEL THE GRUNT.
ABS relay/fuse
16 April 2007, 13:28 »
Anyone know wether the abs has a fuse or relay? if relay what number should it be? looked in my owners manual and it said the abs has a fuse which is above the relays.....anyone clarify...?
Len
10k hero
Re: ABS relay/fuse
16 April 2007, 13:38 »
According to the Bentley manual - no fuse or relay!
Why do you ask?
www.sas.org.uk
www.the-ace.org.uk
Len
10k hero
Re: ABS relay/fuse
16 April 2007, 13:49 »
Aha! didnt quite believe that so did a bit more checking!
There are 2 relays and they are up above the normal relays.
ABS relay - J102
ABS hydraulic pump relay - J185
www.sas.org.uk
www.the-ace.org.uk
DazVR6
Re: ABS relay/fuse
16 April 2007, 14:07 »
Now that ive got a job again i wanna sort out my abs probs once and for all...wanna check these are working correctly before i move on to the expensive parts like the pump.
Already replaced the sensor twice, checked the ring and wiring and still i get the code for dodgy r/o sensor....i suspect its the pump though cos i makes all sorts of noiseswhen driving and im not even using the brakes......funilly enough though when i drive the car hard the light goes out for a couple of hours....weird eh.
Len
10k hero
Re: ABS relay/fuse
16 April 2007, 14:14 »
Any relay can be checked by this method.
Take car for a run and get real warm. Then stop switch off and remove the offending relay, if its warm then its fine, if cold its duff!
www.sas.org.uk
www.the-ace.org.uk
DazVR6
Re: ABS relay/fuse
16 April 2007, 18:03 »
Checked the fuse box....there is no other relays above the normal relays, all i found were the two fuses ontop of the relays....checked these both fine.
Think im gonna leave it to the experts and book it into midlandvw.
Golf mk3
hardmonkeys
ABS relay/fuse
