Author Topic: car fooked, no idea what it is!! do you?? lol  (Read 1883 times)
Offline BobbyT
« on: 15 April 2007, 20:30 »
Hi all, well my mk1 is bust again, i thought it was a faulty fuel pump but i have had this changed and it is still playing up! the simtoms are as follows: You start the car and it keeps stalling and running at about 600 rpm until it warms up a bit and when you start driving the car kind of bunny hops, this keeps getting worse until the car stops all together, the fuel accumulater is quite loud too?? any ideas would be great as i seem to be chucking money at it and its not getting fixed!  :cry:
Offline SpearMintTom
  • DOB: 10/08/1986 - MK1 Golf: 14/02/1983!
Re: car fooked, no idea what it is!! do you?? lol
« Reply #1 on: 15 April 2007, 21:59 »
When was the last time you did a oil filter/oil & coil change?
1983 1.6L 8v: S/S 4-2-1 branch, S/S CentreBox, M-u-f-f Diver exhaust, SPC, Wofsburg Dials + Blue LED Lights, Debadged & Smoothed, Porsche Green,
« Reply #2 on: 17 April 2007, 16:12 »
have you checked for rust in your fuel tank?
Offline [han]
  • Graphic Designer for Haribo
« Reply #3 on: 17 April 2007, 18:13 »
how do you check? this could be my problem?
Offline monzablue16v
« Reply #4 on: 17 April 2007, 18:30 »
Lift the  back seats and remove the fuel sender and lift pump get a torch shine it in the hole and see if it's shiny or rusty in there :)
« Reply #5 on: 17 April 2007, 18:45 »
Oh and don't smoke a fag or have a torch that sparks, hood down as well to let the vapours get out safety first children :D
« Reply #6 on: 17 April 2007, 22:14 »
drop a magnet on the end of a piece of string in there & check the magnet every few days, after a couple of weeks you should have picked up most of the loose rust.  If your filler neck is rusty replace it, then once the tank is clear replace the filter.  If it still does it then rust has got into the fuel systewm and you may have to replace the lot to flush it all out!
