Author Topic: DSG Gear Shifting - 5th gear at 30mph...  (Read 5580 times)
Offline Stiggy
Re: DSG Gear Shifting - 5th gear at 30mph...
« Reply #10 on: 28 April 2007, 23:23 »
Done 1700 miles in my ed30 now - mine also shifts at low revs, but averaging 27/28mpg around town - think it needs a long motorway trip.  I have noticed that the gear change depends greatly on how you use the right pedal, as some of you have mentioned.  Tried launch control as well a couple of times - WOW!  Another thing i've noticed - when i hit 800/850miles, the car sounded and felt completely differently to brand new, as if it were a completely different car.  And since then, till 1500 miles, the car seems to have changed in responsiveness and sound (in a positive way!).  Is this normal?
ED30 gti 5dr pearlescent black with DSG, xenons, bluetooth, tinted windows, ipod, rear parking sensors, highline....and a huge grin!
Offline teebee
« Reply #11 on: 29 April 2007, 13:00 »
"If you do "mash the carpet", using kickdown, then it will always hold the current gear until the rev-limiter is reached, and only then change up."
No it doesn't.
If you kickdown, then lift off, it won't redline. It'll change up.
Offline Teutonic_Tamer
« Reply #12 on: 29 April 2007, 14:54 »
No it doesn't.
Erm, you are twisting words:
If you press the accelerator pedal fully down, so that you have pressed the kickdown switch, and hold the pedal there - then the box will change down to the lowest possible gear, and will NOT change up, until the rev-limiter is reached.
However, if you do lift off enough to release the kick-down switch, then of course it will change up earlier than the rev-limiter, and will revert to using the adaptive shift pattern.
These two scenarios are very different!
« Last Edit: 29 April 2007, 14:58 by Teutonic_Tamer »
I feel like a homo
