Author Topic: Help Advice need!!! Really URGENT!  (Read 1031 times)
Offline BobbyT
« on: 12 April 2007, 13:40 »
Hi all, well i am propper hacked off with the golf! took her out and all was fine but on the way back the car started to cut out when putting your foot down as if the car was running out of fuel! the fuel pump is really loud and sounds like it is sucking on air but i have a full tank of fuel!! any ideas? i need my car for sunday! waaaaaaaa  :cry:
« Last Edit: 12 April 2007, 13:50 by Toofunkyhouse »
Offline Martz
Re: Help Advice need!!! Really URGENT!
« Reply #1 on: 12 April 2007, 14:02 »
Idle control valve?
Offline BobbyT
« Reply #2 on: 12 April 2007, 14:57 »
i am thinking it is the fuel pump? but can a fuel pump kind of work? i only thought it would or wouldnt work?  :undecided:
Offline Fraiser
« Reply #3 on: 12 April 2007, 15:01 »
Do the mk1s have a lift pump also? - If they do id check that as they sometimes go and make the man fuel pump that is under the car strain harder - Check uyour fuel filter also.
hope that helps faiser
