Author Topic: Fly by wire throttle  (Read 1968 times)
Offline Creepy Coupe
« on: 12 April 2007, 12:36 »
Does anyone know if the start point is adjustable, the reason i ask is that on my motor there's no slack point and as a result I have to lift my foot right off the pedal when changing gear, if I don't the revs stay up slightly and gearchanges are jerky.
So I thought if it could be adjusted to give a little bit of free play, like in the old cable days, it might help.
Offline Teutonic_Tamer
Re: Fly by wire throttle
« Reply #1 on: 12 April 2007, 14:30 »
Hmmm . . .
 . . . . it's all to do with emmissions regs.  On high engine revs over-run, the throttle butterfly is held partially open, even with the foot fully off the throttle pedal.  There is a way to defeat it - but it involves dabbing the brake pedal, but that would only be usefull on down-shifts!
You could always ask the main stealer, to see if there is an updated map for the ECU!
I feel like a homo
« Reply #2 on: 12 April 2007, 16:01 »
Hmmm . . .
That's a thought, cheers TT.
