Author Topic: Throttle Body Removel  (Read 2803 times)
Offline GTi5
« on: 03 February 2004, 11:36 »
My 8v keeps cutting out when and stalling when i depress the clutch while approaching junctions and stuff, and i noticed on a previous thread that a mucky throttle body could be to blame. I am planning on cleaning mine out but dont really know where to start.
If any one has done this before then a few pointers would'nt go amiss! :-\
Offline Dizzie
  • Make friends with your fast
Re:Throttle Body Removel
« Reply #1 on: 03 February 2004, 12:38 »
remove the intake pipe and rubber. then disconnect the throttle cable. there are 4 allen head bolts holding the throttle body to the inlet manifold.
you'll need a new gasket when replacing.
Offline GTi5
« Reply #2 on: 03 February 2004, 16:49 »
which gasket? ???
golfvr6
« Reply #3 on: 03 February 2004, 17:09 »
the gasket between the throttle body and the inlet manifold.
Offline GTi5
« Reply #4 on: 04 February 2004, 17:05 »
What i am best cleaning it with? just water or some WD 40 and a toothbrush?
golfvr6
« Reply #5 on: 04 February 2004, 18:53 »
you can use carb cleaner, or wd40  :)
Offline modulater
« Reply #6 on: 04 February 2004, 19:03 »
parrafin or petrol also?
golfvr6
« Reply #7 on: 04 February 2004, 19:08 »
only with a f-a-g in your mouth
 :D
Veedubgt18v
« Reply #8 on: 04 February 2004, 22:34 »
or it could be your throttle micro switch, check the connections from either side of the connectors, and also in the two switches (these are on the throttle body) check the switch with a circuit tester, i cant remember the numbers but golfvr6 may do.
Golfvr6- that switch, my car started doin it again the other day and the cable had fallen off the connector. which was an arse.
golfvr6
« Reply #9 on: 04 February 2004, 23:10 »
when throttle closed, infinite resistance
when throttle open  , 0 resistance
