Author Topic: Dump valve for TDI  (Read 5517 times)
Offline L8
Dump valve for TDI
« on: 11 April 2007, 17:21 »
Help Can a dump valve be fitted to a TDI or is this a no go area? or not worth the effort if you can?  :rolleyes:
Offline GarryR
Re: Dump valve for TDI
« Reply #1 on: 12 April 2007, 13:07 »
Found a link to another forum where the question was asked and it looks like you can fit a dump valve to a tdi but there's not much point. heres the link mate  :grin: http://www.tyresmoke.net/ubbthreads/showflat.php?Number=217205
GT TDI 130, OZ Aristo wheels (Genuine R32's), Eibach springs lowered 40mm, angel eyes and HID Conversion
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #2 on: 12 April 2007, 18:58 »
I fitted one, sounds good, but caused no end of engine probs, not worth the effort
Offline L8
« Reply #3 on: 13 April 2007, 09:38 »
Thanks for the link and reply lad's.  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 02 May 2007, 14:20 »
If you fit a Dual Piston or Squential Dump valve it shouldnt cause any engine problems afaik.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline GazB
« Reply #5 on: 02 May 2007, 18:11 »
Turned out it was'nt the DV causing my probs after, so if you can fit the expence then do it
