Author Topic: Changing thermostat on 1.8 MK2 with power steering.  (Read 2598 times)
Offline MacBain
Anybody got tips on how to change the thermostat on a 1.8 GL MK2 with power steering.
Do I have to remove the entire power steering pump or is there an easier way of doing it?
Would appreciate it if someone has a picture/illustration of what bolts I need to remove in order to loosen/remove the pump :smiley:.
Offline Ktuludays
Re: Changing thermostat on 1.8 MK2 with power steering.
« Reply #1 on: 12 April 2007, 10:00 »
you should be able to remove the lower pas bracket and then undo the 2 pivot bolts and 1 tensioning bolt for the pump. this "should" then pivot out of the way enough.
however on mine the big bolt that holds the lower pas bracket to the upper bracket was not in the mood to move so i removed all the pas pump bolts and cable tied the pump to the front crossmember.
then i removed the alternator and the upper and lower brackets together.
this will give you access to the thermostat housing. undo the two bolts and remove.
refitting is reversal etc............
i have heard that it can be difficult to get the new stat and housing to seal properly and the only way you are gonna know is to connect it all back up and run the engine till hot!!  get a new housing and seal and bolts just to make sure.
i was lucky, mine did not leak.
it may be a good idea to replace the water pump while you are there. if you are gonna take it all off, why do it twice?
the water pump's are only £25 ish from GSF - get a berut one, they are same as the dealers.
good luck!!!!!
<br /><br />What don\'t kill ya, makes you more strong!
Offline Ktuludays
« Reply #2 on: 24 April 2007, 06:49 »
you're welcome  :huh:
Offline MacBain
« Reply #3 on: 25 April 2007, 19:06 »
Tried to change it myself, but I couldn't get the pivot bolt loose, so I let my local vw mechanic change it.
The temprature is now normal.
Thanks for the guide anyway :smiley:
Offline l1ncs
« Reply #4 on: 25 April 2007, 20:05 »
How much did the garage charge to replace it?
Offline MacBain
« Reply #5 on: 25 April 2007, 21:47 »
They charged me about £80, but I live i Norway where everything cost 10 times as much as in the uk :cry:
