Author Topic: sound deadening  (Read 4193 times)
giffy1988
Re: sound deadening
« Reply #10 on: 19 April 2007, 10:39 »
is that how u get rid of road noise den? :embarassed: because i might have 2 get some proper stuff lol
Offline Ben Lessani
Re: sound deadening
« Reply #11 on: 26 May 2007, 22:36 »
the basic principal of sound deadening is mass loading....the more weight you add to a body panel, the less its going to resonate....so you can keep as much volume in the car, without it being wasted making every loose part vibrate.
look here from the 2nd post onwards, http://www.golfgtiforum.co.uk/index.php?topic=49436.10
i layered the entire chassis of the car in bodyline, to replace the oem stuff that got waterlogged. i didnt really notice a massive difference to be honest, i suppose you have to do about 2/3 layers with the good stuff to actually reach any noticeable effect.
if it came to me doing it again, i wouldnt bother. it wasnt expensive, it wasnt time consuming, but i just didnt see any gain in anything. im not faulting doing it (because it obviously works), the only thing to bear in mind is that if your going to do it, do it properly and spend the money on good stuff, otherwise you're just wasting time and effort.
Offline jammac
Re: sound deadening
« Reply #12 on: 01 June 2007, 09:56 »
use loft insulation!!!! my mate has got it in his camper and it works a treat! it used to rattle like f**K with the 4 12" subs going off. but since it was striped out loft insulated and rebuilt the rattleing has gone!
cheap as chips to!  :grin:
ITS A TRAP!
Offline Len
Re: sound deadening
« Reply #13 on: 01 June 2007, 10:58 »
The best points to hit are the lighter panels that resonate. These are usually the doors as they have no stiffening ribs. Even the roof, but only if you dont have a sunroof.
www.sas.org.uk
www.the-ace.org.uk
Offline Heyho
Re: sound deadening
« Reply #14 on: 01 June 2007, 20:55 »
I can see that loft insulation stuffed into voids and gaps might help to prevent rattles, but to stop resonance (which is the main aim as far as audio is concerned) you have to add mass to the most flexible panels - especially directly behind the speakers.  This lowers the resonant frequency of the panels, which in turn prevents them from colouring the sound from the speakers.
Deadening the rest of the car will also reduce general road noise, which will also improve sound quality from the stereo.  I once worked on a 3 series BMW which had had it's entire roof replaced (it also had no sunroof), but had not had the stock deadening replaced, and believe me, when you shut the door, it was like being inside a steel drum!!
The cheap deadening often works just as well as the more expensive stuff, but you'll end up using twice the amount, as it's invariably thinner.
