Author Topic: No rear number plates lights  (Read 743 times)
Offline T_J_G
« on: 05 April 2007, 09:39 »
Went for MOT yesterday, it failed so your chance to help save another GTi.
The rear nuber plates lights don't wok, it's not the bulbs or fuse. Could it be something else?
Where does the wiring run?
Thanks
Tim
Offline fused
Re: No rear number plates lights
« Reply #1 on: 05 April 2007, 09:46 »
check the wiring as it passes out of the top of the boot and into the roof area, sometimes it rubs against the metal and can short. The wiring should be within a flexible rubber sleeve so just work it out from the roof side.
Good luck
Offline Dub-77
  • Dub again MK1 Golf Project
« Reply #2 on: 05 April 2007, 20:28 »
As above the wiring normally brakes as it passes through the rubber boot.
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
