Golf mk4
Golf mk4 TDI
Wazzzer
My 51plate GT TDI 130
Topic: My 51plate GT TDI 130 (Read 3937 times)
colley
Just got here
04 April 2007, 21:38 »
Got the golf bout 1 month ago now.
Get average mpg of bout 41ish.
Max speed of 128mpg (private road?!)
noticed my engine temp sensor has a mind of its own and only work sometimes.
also idles abit jumpy at times.
Any ideas guys?
Any help welcome!
cheers
ExEvo
Re: My 51plate GT TDI 130
05 April 2007, 09:55 »
Hi mate,
I have looked into this and there are quite a few things it could be be. The maf sensor seems to be quite a regular fault. Timing can sometimes be out and even little air leaks.
Hopefully someone with a bit more experience on here can give you some ideas on how to check.
Tim
GarryR
10 April 2007, 14:53 »
Temp gauges tend to jump around a bit and are usually solved by replacing the temp sensor. any good volkswagen garage would change it over for no more than £35 supplied and fitted. my temp gauge would cut out completely sometimes, had the temp sensor replaced and is good as new. don't know about your idling problem though, sorry
GT TDI 130, OZ Aristo wheels (Genuine R32's), Eibach springs lowered 40mm, angel eyes and HID Conversion
spydoor
-[ MkIV GTTDI PD150 - Revo Remap ]-
03 May 2007, 17:27 »
I had a similar problem, turned out the fuse for my air-con had blown. You find it under the battery cover, replaced it and all was well again.
colley
Just got here
maf sensor
21 May 2007, 09:19 »
cheers for all the advise guys.
going to get myself a new maf this weekend, any idea how much i will be looking to pay? is it worth going to VW or just a norm car place
Rhyso
Global Moderator
Sir Postalot
21 May 2007, 09:30 »
VW or motor factors. Make sure you get the genuine one though (think its a Bosch).
Price is around £70 on an exchange basis i believe
Fire Up The Quattro
surreylad1980
Reply #6 on:
25 May 2007, 10:40 »
hi guys
with ref to the lumpy idle, is it when the car is cold,if so put your foot all the way down on the cluctch if it stops then there is an updated ecu which is alot of money let me know
Golf mk4
Golf mk4 TDI
Wazzzer
