Author Topic: Lost Haynes.... How to tighten handbrake?  (Read 852 times)
Offline Mart8V
  • I really should know better by now.....
« on: 03 April 2007, 15:40 »
Can't find the manual- feel naked without it!
How do I tighten the handbrake cable?  Both calipers are biting, but OSR is a little less tight than NSR......  MOT on way.
Offline Daz...
Re: Lost Haynes.... How to tighten handbrake?
« Reply #1 on: 03 April 2007, 16:35 »
Underneath the handbrake cover in the car...you will see the ends of the cables. Nice and easy to adjust to where you need.
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 03 April 2007, 22:29 »
Just to extend a little on the last reply. Jack the rear of the car so that the rear wheels are just off the road, garage floor or where ever you are doing it, and chock the front wheels. Remove the hand brake cover and release the hand brake. At the rear of the hand brake are the two brake cables. These are independant and are not linked in any way, so can be adjusted independantly. Apply the hand brake click by click and turn the rear wheels every time until one starts to get stiff. Then adjust the cable on the free wheel until it is the same. Work the hand brake a few times and test again. Both wheels should be locked at the same time by about 4 or 5 clicks. Don´t forget to tighten up the lock nuts on the ends of the cables and then return the car to normal.
If you run out of adjustment, then the cables are stretched and need replacement.
Offline Mart8V
« Reply #3 on: 04 April 2007, 16:36 »
Thanks for that, guys.  Job for the morning.....!
