Author Topic: strange whine when accelerating!  (Read 2909 times)
Offline Ciaran
« on: 02 February 2004, 10:05 »
well had the car since friday and after tightening the fan belt on friday i can here a whine when accelerating! any ideas?
Veedubgt18v
Re:strange whine when accelerating!
« Reply #1 on: 02 February 2004, 10:48 »
have you over tigthened it?
Offline m4nesh
« Reply #2 on: 02 February 2004, 12:04 »
HOWDY Ciaran
Could be a couple of things as I did have this problem.  When you tightened or changed your cam belt did you change the 'Pre-Tensioner'??  Its only about a ?10 but this usually sqeals if its not changed.....another thing but is not connected to the cam belt is a wheel bearing.
cheers Manesh
Offline Ciaran
« Reply #3 on: 02 February 2004, 13:16 »
no replaced nowt and its not a wheel bearing as it makes the wine even sitting neutral reving it.
im not sure if it made the noise b4 i tightened the belt or if i only noticed it after i had tightened it cos i listened!
Offline Gambit
« Reply #4 on: 02 February 2004, 13:38 »
get somebody to rev the engine while you pinpoint the noise under the bonnet
Offline richandhazel
« Reply #5 on: 02 February 2004, 17:27 »
I assume by tightening the fan belt, you mean the water pump/alternator V belt.
That being the case it could be your alternator bearings. Try removing the V belt and running your engine (NOT FOR TOO LONG THOUGH AS YOU WON'T HAVE A WATER PUMP CIRCULATING THE COOLANT) and see if the noise is still there.
If the noise goes then you may get away with slackening the V belt a little, as Veedubgti8v has suggested.
If it turns out your alternator bearings are knackered, they are replaceable.
If the noise is still there then it is as m4nesh suggests, your timing belt tensioner.
Offline modulater
« Reply #6 on: 04 February 2004, 00:31 »
Rich has hit the nail on the head. tightening the belt  has probably shown up wear in either your alternator bearings or water pump.
The old belt never made the noise appear as it was stretched and as such wasn't running at the correct tension..
Also you say that you tightenend the fan belt, sometimes if the belt is worn it will rub on the pulley and the pulley amplifies the noise.
Like veedub said check the tension and if nessecary loosen it very slightly.
Offline Ciaran
« Reply #7 on: 05 February 2004, 13:08 »
it is the same  belt that was on but had to hand tighten it cos the gearing thing on the altanator is knackered!
