Author Topic: Tyre pressure's....and camber adjustment???  (Read 1034 times)
Offline boneybradley
  • Forum Supporter
  • Back in a Mk3...
« on: 01 April 2007, 12:49 »
Now it's warmer I am starting to do all them job's I have put off and my question's are
What's the best tyre pressure I should run with standard 15" alloy's with 205/50x15 tryes
Is it worth adjusting the camber for better handling?? I have lowered her 40mm on eibach spring's
Are there any other adjustment's/replacement's worth doing to the suspension....I have replaced the shocker's with boge/sachs, front top mount's, front anti roll bar bushes and link's and rear beam bushes.
Offline Len
Re: Tyre pressure's....and camber adjustment???
« Reply #1 on: 02 April 2007, 08:55 »
As you have lowered it you should definitely get the camber checked anyway.
Pressure - I run mine on 32 psi.
www.sas.org.uk
www.the-ace.org.uk
