Golf mk2
Temperature sender
Topic: Temperature sender (Read 4420 times)
Veedubgt18v
Guest
Re:Temperature sender
Reply #10 on:
01 February 2004, 18:21 »
cha ching!
http://www.bigboyztoys.co.uk/index.php?page=shop/flypage&product_id=179&category_id=d57d3ac5fcc57f7d10da5143ab11ba70&ps_session=40aaa6fdff1c8dbd20d7560d4c945e4e
modulater
Reply #11 on:
01 February 2004, 21:07 »
looks good to me ed.
I found this site for basic wiring diagrams of individual dials.
http://www.vegasvik.com/garage/vdo.html
Also found an original 2001 VDO cataloque.
http://www.vehiclecontrols.com/products/vdo_catalog_1.pdf
hope that gives a bit of info
Last Edit: 01 February 2004, 22:18 by modulater
modulater
Reply #12 on:
04 February 2004, 00:06 »
So in theory veedub you'll have the two pole connector at the front and the rear one will have a t piece to run a standard temp sender and a new one for the gauge.
Is this what you got at the moment?
Veedubgt18v
Guest
Reply #13 on:
04 February 2004, 22:42 »
that is it exactly! cos the twin pole temp sender doesnt fit on the back it fouls on the oil filter bolt that holds it to the block if you see what i mean!
modulater
Reply #14 on:
04 February 2004, 22:52 »
Do you think one of those T piece adapters will fit in the gap.
Also look on the link for the VDO cataloque I posted, has the colour adapters to change your dials to green instead of red.
Veedubgt18v
Guest
Reply #15 on:
04 February 2004, 22:57 »
yeah but i will have to cut them open
to get the old red filter out
Veedubgt18v
Guest
Reply #16 on:
i think the t piece will fit tho, i have ordered one from big boys toys
modulater
Reply #17 on:
04 February 2004, 23:06 »
Quote from: Veedubgti8v on 04 February 2004, 22:57
thats a bit of a pisser. No way to unscrew it?
Veedubgt18v
Guest
Reply #18 on:
04 February 2004, 23:08 »
nah they are sealed by the bezel on the front, i will have to knacker it completely to get it open. apparently there are, red green and white lighted ones available from standard. the audi mine came from had a red dash i spose
Veedubgt18v
Guest
Reply #19 on:
it looks ok tho, its not well loud and lairy,but if you get some then find out the colour first!
Golf mk2
Temperature sender
